Can WaterCad import survey files?
We are testing WaterCad and are not sure of it's capabilities.
We want to use survey drawings with WaterCAD.   The piping layout placed on the drawing and the pipe follows the elevations so that the program can calculate friction losses, head losses and head gains.   We also want to create a section views and pipe profiles using the survey map elevation information for the pipe route.
Can this be done using a DGN or a DTM file?
Regan
BPA cad support
