Control Set
Hello Sir,
In my hydraulic model, there are two ESR which are connected to single Pump......then how to create the control set for two ESR....One ESR having 9 lakh lit.and another is 15 lakh lit.
  • Hello Madhusudan,
    You can setup controls for a pump based on different operating levels of two tanks.
    Please see sample models located at C:\Program Files (x86)\Bentley\WaterGEMS\Samples, there are several control examples within these models.
    Also here is wiki about how to create controls, it may help you.
    Sushma Choure
    Bentley Technical Suppport
