I have built up a network, and I have to including color legends for both of velocity for pipes and pressure for junctions. However, the legend text size of pressure color coding is very small and unreadable, unlike velocity legend. How can I increase the text size of pressure legend?Regards,M. Baraa
You can right click on the legend and select scale, it will increase the size of the text of the legend.
You can go through quick start lessons, File>Help>Quick start lessons, which will help you in learning the software.
Here are resources to learn about WaterCAD.
Sushma Choure
Bentley Technical Suppport
Best Regards,M. BaraaHydralics Design Engineer
Hello Mohammad,
I suspect the problem may be related to using color by size, perhaps in combination with the scale factor. Have you tried refreshing the color coding legend or re-inserting? Would you be able to share a copy of the model?
Sharing Hydraulic Model Files on the Haestad Forum
