Hydrant Pressures during MDD
My boss is currently having me run a scenario on Max day settings on a street by opening 1 hydrant at a time. He wants the pressure to drop to 20psi when testing and currently the pressure is sitting around the high 50s and low 60s (psi). Is there a way to force the hydrant to go down to 20 psi?
I am very new to watergems so the more simple the explanation the better.
Thank you
