Hello Everyone,
I have a query regarding displaying the drop depth in a manhole. I have gone through other technical articles available on community like .
My concern is that the available fields in the manhole only help us in working out the drop from the invert of incoming pipe to the invert of outgoing pipe, However, I would like to work out the drop from invert of incoming pipe to the overt of outgoing pipe. The figure of drop from invert of incoming pipe to the invert of outgoing pipe is not of much use. Is it possible to include the information (diameters) of all incoming pipes and outgoing pipes in the manhole properties? That would be of great help in working out the actual drop depths.
Also, i would like to avoid drop at certain locations by increasing the slope of pipes. Can we add information of downstream conduit (within conduit attributes) so that we can select all conduits where there is difference in the invert (stop) of upstream conduit and invert (start) of downstream conduit.
Hope I was able to explain clearly.
Jatin Talwar
Hello Jatin,
What program are you using? In StormCAD (or SewerGEMS/CivilStorm using the StormCAD solver) there are results fields in the manhole properties for "Elevation (Invert Out)" and "Elevation (Invert In)". Moreover, if you have more than one incoming pipe for the manhole, you will see the invert elevation for both listed.
You can use this information to find the drop depth based on any pipe you would use.
Diameter information for the incoming or outgoing conduits is not included at this time. If this is the information that you wish to use, I can make a feature request to see if we can add this to a future release of the product.
Scott
Regarding: "Also, i would like to avoid drop at certain locations by increasing the slope of pipes. Can we add information of downstream conduit (within conduit attributes) so that we can select all conduits where there is difference in the invert (stop) of upstream conduit and invert (start) of downstream conduit. "
As Scott mentioned this is something which can consider as a feature request and get it out in the next release of the product, meanwhile I have a word around which helped me in the past and I hope would be helpful for you as well.
There are two ways here, first is to have all the required result fields annotated on to the network. This can be very useful when reviewing / tweaking a particular sub-network or a portion of the network. But this can be complex and cliche when considering a vast network.
Second best option is to select a particular node on the upstream of which is lies our interest. For quickly getting the upstream elements from a given node we need to use Network tracing from 'Network Navigator'. See snapshot below:
Once the upstream elements are traced and selected, right click anywhere on the workspace and select Edit group to open Flex Table for conduits. right click the Label column and Sort it based on "Upstream to Downstream".
This way, now you have all the information of downstream conduit (within conduit Flex Tables and not Properties window as you asked for) so that we can select/ tweak parameters of those conduits where there is difference in the invert (stop) of upstream conduit and invert (start) of downstream conduit.
Keep us posted on whether this resolved your query.
Happy modelling!
Tanay
Hi Scott, Thanks for the reply.
I have raised two issues.
MANHOLE:
Actually the drop depth we can work out from the available data available in manhole attribute is the difference in invert levels of incoming and outgoing pipes.
Lets take a scenario like a 200 mm pipe connecting to a 1200 mm pipe. Even with overt matching of 200 and 1200 mm pipe, if i use the data of invert of incoming and outgoing pipes I will still get a drop of 1000 mm. But, actually there wont be a drop. Thats why additional information pertaining to incoming and outgoing pipes is required to locate the manholes where actually drop is happening.
I have also attached a snapshot of drop manhole which shows what gets considered as a drop in a manhole. I would like to work out the dimension marked in red. For that we need the diameter of outgoing pipe, diameter of oncoming pipe in addition to the levels (which are available in manhole attributes).
CONDUITS: (My intent is to remove all drops of less than 600 mm in the model by increasing the slope of pipes)
Additional information should also be made available in conduit attributes about the downstream conduit (i.e. Invert Start and diameter). This will really help in saving time.
Best Regards
In this Wiki; how to make the user extension to show the two back drops? your wiki reporting the bigger one once you have two back drops, but needed to present both?
PS: how to present the manhole with two pipes out? one of them is for over flow?
