Gidday,
We can't see any capability in WaterGems to model set point CL2 dosing.For instance, we have a CL2 dosing station at a pump station that is set up like a "mass booster" and only doses when CL2 residuals drop below 2mg/L in the downstream Reservoir (albeit several km's away). However, we don't want the mass booster on all the time, only when levels drop below the target 2mg/L.
We are wanting to simulate this to calibrate our CL2 residuals in our hydraulically calibrated water model.
There appears to be no control logic or control conditions to turn CL2 dosing on/off in WaterGems, just pattern based profiles?
Many thanks,
Stephen Royds
