I have a Variable Speed Pump Battery with 1 lead and 3 lag pumps. At my model conditions only one pump operates during the run duration (1440 min). For some reason when I look at the VSPB run time in the Scenario Energy Costs it is greater than my total run time. It states that the VSPB run time is 5,184,000 minutes.
Hello Alison,
Please provide your model files for us to review as explained in this link.
Craig Calvin
Bentley Technical Support
So you know, we are looking into this issue and will let you know when we have some additional information for you.
Scott
Thanks!
This has been resolved (reference number 727519). The correct time of use will appear after downloading and installing the latest patch set. This is documented in the following article.
Scenario energy cost "Time of Use" doesn't match calculation options "Duration"
