The following error is shown while building a model using model builder from a CAD DXF file, for a Sewer network in SewerGEMS.
Please help on this.
Thank you.
Start with the following directions for performing a clean uninstall and reinstall of the software. There is not a need to delete the licensing information, so that part of the wiki steps doesn't need to be performed.
If the DXF file can be exported to another format, such as shapefiles, that should workaround this issue too.
Mark
