Hellow , i want to ask that should any DMA in water supply be sorrounded by boundary pipelines?? or its upto us to sorround it or not ?Hello
Hello Waqas,
Please elaborate on what you are trying to do. Are you looking for a way to display the boundary of the DMA?
Take a look at the video in the section "Identifying District Metering Areas" in the article "Using the Pressure Zone Manager".
Also, the article "Modeling a District Metered Area (DMA)" might help.
Craig Calvin
Bentley Technical Support
I assume, you mean to say larger sized pipes on the periphery of the DMA, correct?
If so, it entirely depends on the designer and supply conditions. One can also consider feeders instead of supply from boundary pipes.
Please see fig below if that helps.
If not, Could you please elaborate the query in detail?
Tanay
