publish i-model error
  • It appears that you are using different region and language setting based on the error shown. Please try the fix from this wiki where you change the region and language setting to English. If you are more comfortable with a different language I would encourage you to locate the latest version of the software using that language and install it to try to workaround the error.
    Mark
