Insert pressure junctions at regular intervals
I'm currently working a 12km long pressure pipeline where i would like to insert pressure junctions at regular intervals (every 50m) to enable ground level to be referenced along the pipeline.
Is they a tool avaliable to automatically insert these juctions along the pipeline at the specified interval? I'm trying to avoid inserting these manually.
Matt
