When I load demands into watergems they are all loading on one point in the model. When I open this same shapefile in arcmap all the points project where they should. Does anyone have an idea why this is happening?
If all loads are seen in one node after running Loadbuilder, it is an indication that the model is not lined up with the related Shapefiles, as Scott mentioned. In that case, all features in the shapefile may indeed be closest to one single node on the outside edge of the model.
See related:
Not seeing new demands or customer meter assignment after running Loadbuilder
WaterGEMS Loadbuilder - Nearest Node goes to single node
