Hello, I have some questions related to the SCADAConnect module.
Does the program continuously update data from SCADA system or does it require manual data updating?
Hello Aleksandra,
SCADAConnect can use real-time or historical data. So if you have a SCADA system that allows real-time model, this can be done in SCADAConnect Simulator. The following link has some additional information on SCADAConnect Simulator: SCADAConnect Simulator for WaterGEMS (V8i SELECTseries 6 and CONNECT Edition).
Scott
Answer Verified By: Aleksandra Tor
In the article Scott mentioned, you may want to take a look at the Live (Auto Compute) option for the "Simulation mode" dropdown at the bottom of the Home tab of SCADAConnect simulator.
