SewerGEMS Modeling a Transition Manhole (Force Main to Gravity Sewer)
Hello ,
I was looking for feedback on the tools available in SewerGEMS to model a transition manhole. (solver options, physical elements to include, etc..)
My objective is to model as explicit as possible the transition between pressure - gravity flows, including  the effect of energy dissipater in the transition manhole, assess the culvert entrance capacity (inlet control).
Thanks in advance for your help,
Dennis Lopez
  • To model a transition manhole you can use one of two elements: manhole or a transition. This wiki explains the differences in connections for a manhole vs. a transition vs. a pressure junction. In this case it may not matter much which element that is used, but if the element connecting the gravity main to the force main has a depth to it beyond the depth of the connecting pipes I would recommend using a manhole.
    The energy dissipater could be modeled in 1 of 2 ways depending on what you think more appropriately represents the element. It could be modeled using a headloss at the node element (manhole or transition) using the absolute headloss method or it could be modeled as a start control structure on the conduit. To model it as a start control structure on a conduit set the property labeled "Has Start Control Structure?" to 'True' and choose the control structure (depth vs. flow curve, weir, orifice, or functional) that best models the structure.
    Mark
    Answer Verified By: Dennis Lopez
