Ref :https://communities.bentley.com/products/hydraulics___hydrology/f/haestad-hydraulics-and-hydrology-forum/140158/error-occur-the-given-key-was-not-present-in-the-dictionary-in-water-gems
hello Sushma Choure.
i am facing a problem in Sewer Cad Outfall show in flex table but Not Present in Model When i am search X Y Cordinates in model outfall was not present there...
please help!!!!!!!!!!!
Hello Abdul,
Did you make the outfall inactive & unchecked the option of display inactive topology in drawing?
If that is the case, then please go to Tools>Options>Display inactive topology.
If that's not the case, then please compact the database, as explained in the below mentioned wiki.
Compacting database
Sushma Choure
Bentley Technical Suppport
Here are some additional thoughts:
1) From the flextable, you can right click on the row header (gray area on the far left side of the row) and choose "zoom to" to pan to the coordinates of the element.
2) Ensure that the Outfall element has a check box next to it in Element Symbology (make sure it's not set to be hidden)
3) In case you are zoomed out too far or the symbol sizes are too small, double click the outfall item in Element Symbology and check the symbol size multiplier in the properties. Also try setting the outfall element or the global symbology drawing style to GIS. See: Changing drawing style for better viewing of element symbols and annotations
4) Check if zoom dependent visibility is set. See: Some of my elements disappear when I zoom close in or zoom far out in my model
5) If the above doesn't help, close the model, delete the associated .DWH file and reopen. This will cause the model to re-draw the plan view.
Adding to Sushma's and Jesse's suggestions:
1. Refresh the drawing (F5, or View > Refresh Drawing)
2. Enable Auto-Refresh (View > Auto Refresh)
3. Refresh Element Symbology
4. Synchronize the Drawing
5. Make sure there isn't color coding applied to the outfall that is making it appear white.
Craig Calvin
Bentley Technical Support
The following article includes all of the above suggestions.
Elements and/or annotations are not displaying in the drawing pane
