Hi
I am working on the design of a WDN for a village which is located in a valley. The reservoir is located on a top place and water goes through the valley and then comes up on the other wall!.
The village has a main road with the slope of about 9% . I designed my main pipe from the reservoir to this road and then take approximately horizontal lines in the second paths and then for the connections.
Is it possible the water to runaway to the downstream of the main pipe line and from the access of upper places? How can I check this in the watergems?
The height difference between reservoir and the lowest point is 60 meters.
Don't worry. Outflow from the system is controlled by the opening of faucets, showers and other orifices. It is not as if pipes are just discharging to atmosphere.
Do you mean if I need to insert any faucets or valves? Or the system automatically does it?
When you place demand on a node, the model assumes that you have based it on the actual demand and it doesn't matter if it occurs at a faucet, shower, dishwasher, toilet, etc.
Ahan. Thanks.
I think it is needed that I explain more and ask some more questions:
I have designed one water distribution network in a village where there is a main road and the houses are spread two sides of it. The main road is in slope, the slope is about 9% and the height difference between reservoir and the lowest point is about 60 meters. I simulated the main pipe in the main road and then split it and branched in each lane.
Now I want to know if enough water reaches the connections in upstream or all the water moves through the main pipe towards the houses of downstream?
On the other hand, if I wouldn't be sure about the reservoir outlet to be full (along the pipe, to the end of it), how can I simulate this and see the results?
