How to import sanitary loading (Unit Load) from user defined tables in Modelbuilder, (in new version) it is in non-editable form,
whereas in the earlier versions from import options directly we can able to import the loading.
Raj.
Hello Raj,
The screenshot attached is from the older version of SewerCAD, what is hte version that you are using now?
In the latest versions you can import the loading information using tools Modelbuilder and Loadbuilder. Tools>Modelbuilder, Loadbuilder.
If you have loading information in the formats like shapefiles, excel files then you can import that using Loadbuilder and Modelbuilder tools.
Loadbuilder methods
Importing loading information using Modelbuilder
Also you can directly enter the loading information through Tools>Sanitary load control center for V8i versions and components>Laoding>Sanitary load control center for connect edition versions.
Sushma Choure
Bentley Technical Suppport
Answer Verified By: Jesse Dringoli
