StormCAD V8 Lock up when calculating
I'm modelling a storm sewer system in Select Series 5 which is built from a Land XML file exported from a Civil 3D 2015 pipe network. When I try to run the model and the calculate window appears, the software locks up on "Loading Input". I gave it just over an hour while I worked on other things but with no progress had to force close the model. I suspected it had something to do with pipe size vs. what was in my library. I did not have 5'x4' concrete box in my catalog (which was in the model). I left the conduit on User Defined but with the size added into the catalog and got the same lock-up result. I then changed the conduit to Catalog Conduit  and got the same lock up result. Lastly, I built the exact same model but manually (i.e. without importing XML - I typed in X/Y coordinates on structures). This model runs beautifully. The problem is I have a quite a few of these to do and starting from an XML import would save a lot of time. Has anyone experienced a similar issue? Any tips or items to check to have the XML import work correctly? I've done it before but have not run into this issue, which is why I suspected something with the catalog.
As a side question, does it matter whether or not a conduit is in the catalog if set to User Defined in the model?
Thank you for any assistance,
Louis
