Dear Gentlemen
Good Day
Regarding the above subject, I would like to clarify that I have a global storm water model (city level), I need to select network elements (manholes, catch basins) within a limited geographic extent, in order to show the hydraulic results in the study area. please advise on the way to implement it using sewerGems V8i select series 5.
With My Best Regards
Hello Huthyfa,
You can select the elements in SewerGEMS within the specified area by you, for that please go to Edit>Select by polygon.
Sushma Choure
Bentley Technical Suppport
Answer Verified By: Huthyfa Ahmad
Thank You very Much, This really works
See related wiki article:
Selecting multiple elements for a selection set
Thank You very Much
