I have given same base load to manhole and they are having same peak factor, but my result shows different value. I am using Connect edition.
In addition to that at the point of transition, total inflow should not be equal to total flow?
Hello Nawnit,
Please provide the model files using one of the methods in the following article.
Sharing Hydraulic Model Files on the Haestad Forum
Craig Calvin
Bentley Technical Support
Actually, it was interpolating the peak factor. I wanted it constant, so I modified the extream flow factor table and my problem was solved.
Thanks for your reply.
Answer Verified By: Nawnit Kumar
