I'm looking for a way to compare 2 tank HGLs for a pump control.
For example:
If T-1 HGL >= 100 AND T-1 HGL > T-2 HGL Then turn off pump.
So I want to turn the pump off when T-1 HGL is greater than 100 but only if T-2 HGL is larger than T-1 HGL.
Any thoughts on how to accomplish this?
You can apply operational controls on the pump in the pump properties. As per your example I have modeled a small network wherein I have specified a few controls on the pump operation. However the control can be set to a particular value only. For example Time > 14:00; HGL >=100 m; Flow > 10 L/s. For comparing the HGL's of two tanks you need to find the relationship between the two tank HGL's and a control can be set such as HGL for T-1>=100 m AND HGL for T-2 >=102 m.
Please see the snapshot of the model. If it is not similar to the case you are describing please share your model via the link provided.
Link for Uploading Files
Here is a relevant wiki article for creating conditions, actions and controls.
Creating Controls - Conditions, Actions and Control Sets
Yashodhan Joshi
Bentley Technical Support
