The scenario is as follows:
I have uploaded hydrants to Watergems via modelbuilder. This resulted in floating hydrants with no hydrant laterals. I am interested in finding the best way to establish a node in the pipe closest to the hydrant. The node would then represent the hydrant and have the same label as said hydrant. The goal of this is to eliminate the lateral length and hydrant altogether and have Fire Flow scenarios run and tested directly on the main pipe. I have tried making a tap in the pipe, but this results in associating the tap in the center of the pipe and does not establish a node near the hydrant. What would you say the easiest way to do this would be? I am very open to ideas and suggestions.
Hello Adam,
You could use the tool – Batch morph which will convert your hydrants into junctions, but it will not give you same labels as that of hydrants.
Sushma Choure
Bentley Technical Suppport
This does make sense but how are we to make hydrants into junctions and then associate them with the given pipe when they range from 5 ft to 35 ft away from the water main? Does this seem like to much of a tolerance?
Alternatively, if we wanted to use the hydrants as hydrants and keep them where they are, how do we add a lateral to associate the hydrant to the nearest pipe for use in completing the available fire flow function?
Currently, taps and laterals are not supported with the hydrant element (see this article). There are some complications, because the hydrant element already has a built-in option to represent the lateral losses.
If your hydrants are too far away from the main pipes and Sushma's option won't work, you could try something like this:
a. Export the hydrant flextable to shapefile, inlcuding just the label field.b. Delete all hydrantsc. Import the shapefile using ModelBuilder, with the customer meter table type and label as the key field.d. Use the customer meter method in LoadBuilder to automatically assign the customer meters to the nearest pipe. Choose the option to create the taps and laterals automatically.e. Delete all the laterals and customer metersf. Export the Tap flextable to another shapefileg. Delete all tapsh. Import the taps shapefile using Modelbuilder with the Hydrant table type and label as the key fieldi. Run the Batch Pipe Split tool to connect the hydrants to the pipeline.j. Use the lateral loss option in the hydrant properties to account for lateral losses, if needed.
Hello Jesse,
I have had success up to the point of step d. Once I assign customer meters to the nearest pipe via loadbuilder, it appears that an amount of meters still assign to nodes. Is there a way to override this such that the meters do not associate to nodes at all? This seems to typically happen at dead-end water mains and some miscellaneous intersections. For reference, out of 502 meters, 464 of them were associated to pipe; this left 38 meters associating to nodes instead of pipes. This is a problem because 38 of these meters do not have taps and will not be included in the exporting shapefile. Any easy way to fix this?
Best,
Adam Carrier
Thanks for pointing out the oversight. Try this:
d2. Home > Select by element > customer meters (to select all of them)
d3. Network Navigator > Network Trace > Find elements associated with customer meters
d4. Tools > More > Batch Morph
d5. Choose "selection" for "choose nodes to process" and select Hydrant as the new node type.
