I cannot get element symbology to work. Pipes, nodes, etc are white and will not color code. Displays properly in Aerial View, but not main window. FYI, recently upgraded from 08.11.04.58 to 10.01.00.72
Hi Craig,
Try synchronizing the drawing and compacting the database as explained in the following link.
Element annotations (labels) or color coding are not displayed correctly in the drawing pane
Craig Calvin
Bentley Technical Support
I performed both tasks and it did not fix the issue.
Here are some additional things you can try. I recommend trying them in the order they are listed.
Answer Verified By: Craig
Option 1 did the trick. Thanks!
