excuse me, how can i get a bing map key?
Hello Pan,
Bing map key needs to be generated using the Bing Maps Dev Center, which has been explained in the below link of Microsoft.
Getting a Bing Maps Key
Here is more information about new features of WaterGEMS 10.01.00.72 version which you are using.
What's New with WaterGEMS and WaterCAD CONNECT Edition Update 1
Sushma Choure
Bentley Technical Suppport
I got a bing map key and loaded it into my model, but the pipe network shows in a wrong location.
I think the bing map coordinate is wrong, is that because of the control points?
Hello Pan, you may need to use control points to align the background with the model, in case they use a different coordinate system. I recommend using the 3 points option. With this, you select a point in the model, for example a hydrant, then pick the corresponding point on the map (the location of the hydrant). Do this for three points and the map should align.
We will be posting a short video about this on our Blog and YouTube channel very soon.
Jesse DringoliTechnical Support Manager, OpenFlows ProductsBentley Communities Site AdministratorBentley Systems, Inc.
The video Jesse mentioned is now posted to our Blog and YouTube Channel.
Craig Calvin
Bentley Technical Support
Please note that a subsequent reply to this thread has been split off to a separate thread here: SewerGEMS Bing Maps feature
