Hello Atif,
In Civil3D you can try exporting the file as a LandXML file. This format can then be imported into SewerGEMS by going to File > Import > LandXML.
Scott
You can also read more in the following article from our Wiki:
Civil3D integration (Pipe network import/export)
Thanks Scott for your reply - but I already tried this and it can't work for me.
How I share my Land XML file to you so that you will see the problem.
Please provide more details on the problem you're experiencing with LandXML import (Error? Missing data? Something else?) Please also let us know what version of SewerGEMS you are importing into.
If you have not read it already, the article I linked to in my previous reply has some information regarding LandXML import/export.
If you need to send the model or the LandXML file, see: Sharing Hydraulic Model Files on the Haestad Forum
