Originally posted to this link: communities.bentley.com/.../pond-s-water-level-stays-stagnant-over-time-even-though-there-is-culvert-to-empty-it
Dear Scott,
could you please tell how we set up composite structure in SewerGEMS for detention pond with out let pipe to chamber to outfall? would you please share example model?
Hello Mohamad,
By looking at the image you provided, I think that the part you labeled "outlet structure" would be best modeled as a manhole or catch basin. I attached an example model and a profile to show my recommended approach.
Detention Example.zip
Craig Calvin
Bentley Technical Support
