Need help working from home with your Bentley software? We're here to help - click here
CHALLENGES FACED WHEN CHOOSING THE CORRECT PUMP SIZE DUE TO NO FRICTION HEAD LOSS BEEN CALCULATED ON THE RISING MAIN IN THE SYSTEM(SOURCE TO TANK) 2.)NEED FOR CUMULATIVEFRICTION HEADLOSS
Hello Bentley Communities,
I am facing challenges when it comes to choosing the correct pump size for my water system.WaterCad is not able to calculate for me friction head loss in the pipes and I will assume this is because of zero-flow in the pipe, yet I have entered the demand at the end of the pipeline.Can WaterCad be able to calculate head loss due to friction or in other words allows flow in the rising pipeline from the source to a tank on the upstream side of the network? ; as it is possible when designing a rising main from any source to a node located at a higher elevation?Is it because of the tank that the system will not allow any flow?In the case where I replace the tank with a junction node then losses will be calculated in the pipe.
How will I be able to choose the correct pump size for my network since I need to know the total amount of pressure of water needed at the end of the network(which is a function of friction losses)/Is there a way that I can allow friction losses to be calculated without removing "TANK 5"
Please have a look at the attached file.SITIKHO buyofu ANALYSIS.rar
The second question is that I would address the need for Cumulative friction losses along the pipeline.Can you guys please introduce it the pipe flex table?
