Need help working from home with your Bentley software? We're here to help - click here
Can a pump serve more than two tanks on the downstream side served by a single rising main pipe
Hello Bentley family,
Can a single pump be able to pump water to two or more tanks placed further downstream from the first tank all located along the same rising main line but the tanks having higher physical elevation than the 1st tank?
Please have a look at the attached file in order to have a better understanding of my question  Khasoko Buyofu.zip
My question is, After choosing the right pump that is enough to pump water up to the furthest and highest point in the model with the inclusion of all loses; why is watercad unable to allow water to flow to the 2nd tank?Is it because pressure gets back to zero when the surface of water comes in contact with the atmosphere at the tank?What measures should I use then or controls?Should I introduce a gate valve?
