We are planning to import a shapefile for a City into SewerCAD.
There are four sewer systems. One of them has 6 lift stations and another has 2. The rest are small sections with 1 lift station.
If I create a scenario, are we running all four sections at the same time? They are not interconnected.
Yoko
Hello Yoko,
You can have multiple systems in the same scenario (they don't have to be connected) and they will all compute at once.
You can also use active topology to separate them into different scenarios.
Craig Calvin
Bentley Technical Support
Answer Verified By: Yoko
Craig,
Thank you so much for your reply!
