Trying to use some basic Autolisp scripts while in WaterCAD for AutoCAD (not WaterCAD standalone). Doesn't work. Doesn't even give an error message. It just does nothing. If you suggest perhaps the AutoLisp routine is poorly written, I have tried every AutoLisp, plus some AutoCAD commands that are written in AutoLisp, none of them work.
Which version of WaterCAD and AutoCAD are you using? You can check the compatibility of both the products and preferably update them if not compatible.
Do the AutoLisp scripts work in plain AutoCAD?
You could try re-integration of WaterCAD and AutoCAD by going to Start > Programs > Bentley > Integrate WaterCAD with AutoCAD.
Here is a relevant article on some troubleshooting steps you can look at for AutoCAD integration;
AutoCAD Integration Troubleshooting
Hope this helps.
Yashodhan Joshi
Also - it is possible that your scripts are conflicting with components loaded by WaterCAD. What do these scripts do? (what do you need to accomplish while working in WaterCAD for AutoCAD?) It is possible that we may be able to determine a workflow for you to avoid this problem. For example see: CAD Functionality in Standalone as an Alternative to AutoCAD or MicroStation Integration
