In the RNE OS.070 of PERU, I request a minimum flow in the starts of 1.5 l / s, meaning that the initial flow of the pipes will be at a flow rate of at least 1.5 l / s, however when I reach the first Buzon (BZ) I have the need to have two outputs and I am forced to use the "IS DIVERSION LINK", and I could indicate a flow rate of 0.75 l / s to pass through each half, however this flow would not comply with what is requested in the RNE OS.070 of PERU, in view of the fact that they require me to comply with at least 1.5 l / s. what they recommend me to do.I appreciated your response, thank you.
Hello Richard,
When your conduit splits into two at a manhole the flow will also split. Since your upstream conduit is carrying 1.5 L/s the flow will be divided among the two downstream conduits. The flow split may or maynot be equal (0.75 L/s per conduit) and depends entirely on the diversion rating curve you specify at the diversion link.
If you want minimum flow of 1.5 L/s then you would have to add flow at the manhole so that the downstream conduit also has a minimum flow of 1.5 L/s.
In addition to this as a tip you can use the design constraints under Analysis > Analysis Tools to define minimum and maximum velocity, slope and cover. These design constraints help you design your model as per standard practices followed.
If you are using SewerGEMS or SewerCAD you will find the "Design Alternative" in the Help section. You can refer it for more understanding.
For your reference here is the relevant article for modeling flow diversions;
Modeling a flow split (diversion)
Hope this helps.
Yashodhan Joshi
As Yashodhan mentioned, you'd need to adjust loading to cause the flow to be at least 1.5 L/s, but it seems odd to me to do this to force the model to show a specific flow.
Could you provide more details on this requirement of a minimum of 1.5 L/s? Is this to ensure pipes are self-cleaning? If so, you could look into the Tractive Stress design constraints, though it may not result in the flow you desire.
You could also try modeling the flow split as an outfall with two separate manholes for the downstream systems with a load of 1.5 L/s on each, but then the backwater profile calculations (HGL) won't propagate through this.
Agradezco su respuesta, esta exigencia lo señala el Reglamento Nacional de Edificaciones en su capìtulo OS.070,
en el Pais de PERÛ
que textualmente señala lo siguiente en el îtem 4.6..
Adjunto el archivo PDF.
PDF
Cuàl deberìa ser el caudal inicial en los buzones de arranque??
Muchas gracias por su respuesta.
Richard, are you able to communicate in English? If so, could you clarify the last part of your previous response? If you want both of the downstream pipes (going away from the diversion) to have a flow of 1.5 L/s, you would enter a fixed load of 1.5 l/s on the two manholes seen in my above screenshot.
En español:
Richard, ¿puedes comunicarte en inglés? De ser así, ¿podría aclarar la última parte de su respuesta anterior? Si desea que las dos tuberías aguas abajo (que se alejan de la desviación) tengan un flujo de 1.5 L / s, debe ingresar una carga fija de 1.5 l / s en los dos pozos de registro que se ven en la captura de pantalla anterior.
I believe this requirement of 1.5 L/s comes from tractive force design. In order to calculate tractive force (it's actually a stress, not a force), you need to know the flow and then the hydraulic radius.
The flow and hydraulic radius are easy to calculate for pipes with an appreciable flow. However, in upstream pipes, the flow is intermittent. You get flow when someone runs the shower or dishwasher but then you get zero flow much of the time. With these highly varying flows, someone had to come up with a flow rate to use to calculate tractive stress. So someone said "let's use 1.5 L/s" and a lot of people use it. However, it doesn't make much sense in models.
A simpler approach to ensure adequate slope is to look at the graphs in ASCE manual 60 "Gravity Sanitary Sewer Design and Construction." It says that for a Manning n of 0.013, adequate tractive stress occurs at a slope greater than roughly 0.004.
Most reasonable regulators realize this.
It's also unusual to have flows split in upstream pipes at the "first Buzon" (mailbox?)". Does this occur at many places in your system? If so, why?
