I have an old Cybernet model that is in a .dwg file. I don't have watercad for autocad. Can you convert the .dwg file to a watergems file?
Jesse Dringoli
I have exactly the same situation and would really appreciate the help. Do you think you can convert the model for the DWG file I have?
I will upload the relevant files through the secure file upload with the link to this thread, in case you can.
yes, if the DWG contains the Cybernet model, we can try to convert it as I still have access to a Virtual Machine with WaterCAD V7 for AutoCAD 2006. Would you mind starting a new forum thread for that, with the name of the uploaded file?
Ok I'll do that
