Need help working from home with your Bentley software? We're here to help - click here
Headloss through Flow control Valve
When I model a flow control valve, it shows headloss (to the tune of 68.80 metres) whereas as per valve manufacturer, it shall not be more than 4.0 metres.
There is no option of specifying the headloss through the flow control valve. How can i achieve that ?
