Dears,
How can i change the load definition in the sewer gems, from pattern load to Sanitary unit load, as i entered the population as point load and after that i need to change the base flow to be unit load by population not flow.
Hello Mohammed,
Go to Sanitary load control center>click on New>Initialize units loads for all elements. This will allow you to enter number of loading units i.e. population count and specify the sanitary unit load.
You can delete the sanitary pattern loads from the sanitary load control center if those are not required and you want to continue with sanitary unit loads.
Sushma Choure
Bentley Technical Suppport
Answer Verified By: Jesse Dringoli
As Sushma explained, you would need to create new unit loads and then delete the old pattern loads.
Here are a couple of related links that explain this in more detail.
Can't change Unit sanitary Load
Understanding the Sanitary Load Control Center and Inflow Control Center
Craig Calvin
Bentley Technical Support
