I am getting this error “An item with the same key has already been added” when changing Scenarios. Particularly after adding additional Nodes after reaching 100 Nodes (even though I have CivilStorm activated). Does this affect any Runs I make hydraulically or can I just ignore the error?
Hello Kenneth,
Please provide the following:
See: Sharing Hydraulic Model Files on the Haestad Forum
Craig Calvin
Bentley Technical Support
Hi Craig, I've just uploaded the .dgn, the contents of the text after the error dialog, and the application/version information to the Bentley Secure File Upload site.
I see that you are using a Civil product, not a Haestad product. Although it may be related to the Haestad technology inside of GEOPAK V8i SS4, it could be a problem on the GEOPAK side. Do you have plans to upgrade to OpenRoads Designer? It uses a newer version of the Haestad technology. If I open this model in the latest version of CivilStorm, I do not experience any errors when switching scenarios. I have asked my colleagues to try to reproduce this in GEOPAK.
Based on the error details, I am not sure what could cause this or what the impact is if you ignore it. I did notice that you have a rogue pond outlet entrance node very far from the model, labeled "POND-OUT-", which is attached to pond "POND-PR-32F-99". It is located at 334,355.33 ft, 579,705.30 ft, which is about 288 miles away from the main model.
I could reproduce the issue with Power Geopak 08.11.09.878 version, as mentioned by Jesse we couldn't reproduce issue in the latest version of OpenRoads Designer, is it possible for you to upgrade?
If not we will work on further to rectify this issue in Power Geopak.
Here is information about OpenRoads Designer for your reference.
OpenRoads Designer CONNECT Edition - Wiki Articles and Videos
Sushma Choure
Bentley Technical Suppport
Hi Sushma,
I tried to open the .dgn in OpenRoads and got a popup saying "the Civil Data is not supported" and then it proceeds to only open Read-Only. How did you open the file and does it require some sort of filetype export? Also, is there an OpenRoads workspace we can use? (We currently don't have one set up as we primarily use Power Geopak)
