Hello ,I would like to create an animation shows the pressure changing over 72 hrs. in my network and may record that animation to send it to someone else or archive it for future references. Would you please guide me to the steps!Thank you,Zaid
Hello Zaid,
The following article contains steps to create an animation, including a video demonstration.
Using the Record Animation feature to record and play back videos without any other software
Craig Calvin
Bentley Technical Support
Hello Craig,
Thank you for your reply. I cant find the Timer Browser whether under Home of Analysis tab in WaterCAD Connect Edition Update 1Vi8 ?
Zaid
Look under analysis > Times.
Hello Dr.Tom
I got it . One more question, If I need to specify that video for showing pressure changing overtime, what are the steps required?
Zaid Subhi said:If I need to specify that video for showing pressure changing overtime, what are the steps required?
1) Set up the pressure color coding.
2) Zoom to where you want to record (or zoom extents if you want the whole model)
3) Open and configure the record AVI tool in the Time Browser
4) Press the record button - the animation will start, the colors will change accordingly and the video will be recorded.
See the video at the bottom of the article that Craig had linked to.
