Is this analysis the same as evaluating a demand for fire in each hydrant?
No, this analysis tells you how much water can be delivered to the node at the specified residual pressure.
Paula,
Here are a couple of articles that explain how the automated fire flow analysis works.
How does the Automated Fire Flow analysis work?
Understanding Automated Fire Flow Results
Craig Calvin
Bentley Technical Support
