I was trying to run WaterCAD Vi8 model onto EPANET 2 model, but there were a numerous warring messages. Does that mean, both software have different engines that do no interpolate the water network in between smoothly ?.
Thank you,
Zaid
Hello Zaid,
The following article explains the limitations of exporting a WaterCAD model to an EPANET model.
What are the limitations of importing/exporting EPANET files?
The next article should also help explain the differences between the solvers in WaterCAD and the solver in EPANET.
Should the EPANET solver and the WaterGEMS/CAD solver give the same results for a model?
Craig Calvin
Bentley Technical Support
Hello Craig,
Very helpful links. Thank you
