Dear Yashodhan JoshI Sir,
I am beginner of SewerGems I have draw a network I have area 235 acre,
My question is how do I calculate demand for each Manhole by using area.
It's my first design so you are requested please tell me how I calculate
I had already designed so many water distribution system and this is not like that
Please help
Hello Sanjay,
I recommend using the LoadBuilder tool. The following TechNote contains a list of articles that explain how to use this tool.
Troubleshooting and Understanding LoadBuilder
Craig Calvin
Bentley Technical Support
If you have a single polygon shapefile and you wish to assign loads based on area, you could consider using the Load Estimation by Land Use method in LoadBuilder. This will distribute loads to manholes based on the desired flow per area along with the area of the manhole's associated service area layer. See this recent, similar discussion.
