Hello All,
I am working within SewerGEMS (Version 10.01.01.04) with a co-worker to attempt to display wet weather flow data through a specific conduit against actual flow meter data that we have for a meter located within said conduit. The way we are currently doing this is exporting the modeled flow data into excel, then lining up the peaks of the events against the metered flow data that we have. However, the client we are working with would like to be able to view the observed and modeled data side by side within SewerGEMS using the "Graph" function. Is this possible? Is there a way to load actual time series, metered data into a conduit? Any help would be greatly appreciated.
Connor Rutten
Hello Connor,
You should be able to import the field data into the Time Series Field Data manager. You can then add the field data to a graph of flow in SewerGEMS to compare the results. This can be useful for comparison and calibration purpose. The following link has more information on setting this up: How do I enter time series field data and add it to my graph?
Scott
The SCADA element can also be used to graph your flow meter data. Here is an article that explains how to do this.
Using the SCADA Element for annotation and reporting
Craig Calvin
Bentley Technical Support
