Pipe labels
I moved up to using WaterGEMS V8i 10.01.01.04 a while back.  Ever since then the pipes that I add junctions to have parentheses with a number following the actual label, P-20 (1).  If it gets split again I get another set of parentheses, etc.  Is there a way to turn this off?
