How to sort the graphs in the new version of WaterGEMS 10.01.01.04 (30/4/2018)? We have hundreds of graphs saved in some models as part of the model calibration. it was easy to find using the sorting function in the old version.
For WaterGEMS CONNECT Edition Update 1 onwards we have introduced a "tree" type structure with the ability to create folders for storing graphs. You can create as many folders as you like and store graphs as per your requirements. The sorting functionality was not available before. Can you explain how are you using this? Which version of WaterGEMS did you have previously? Can you provide a acreenshot of the functionality you were using?
In addition to my response here is a reference article which details the different features in the latest WaterGEMS version (10.01.01.04)
What's new in WaterGEMS CONNECT Edition Update 1 (Build 10.01.01.04)
Hope this helps.
Yashodhan Joshi
Hi Yashodhan, Thanks for your response. The version we are currently using is 10.00.00.55 (22/5/2017 build), in which all graphs can be sorted using the label. The new version we are testing is 10.01.01.04. It can create folders which is flexible. But it seems the sorting function is removed.
Hello XJ,
Please allow us some time, till we check with development team if sorting of graphs as per labels feature was available in earlier versions and if it has been removed from the latest versions.
Sushma Choure
Bentley Technical Suppport
Apologies for the delay. I do see that you can sort alphabetically in the older version by clicking the Label column header, which is no longer possible in the new tree-view graph manager. I'm checking to see if the tree view can be enhanced to enable sorting. Thanks for your patience.
We have filed high priority defect for this issue, reference number is #955256, to enable sorting of graphs alphabetically as per labels in latest versions as well.
We can expect patch for this soon , I will send you mail with link to download the patch once I receive it from development team.
Answer Verified By: Jesse Dringoli
