Hello all,
I import my drainage network from inroad and created some in stormCAD. I created some fake catchbasin to start gutter but why it is not allowing me to put my length width and other constraints in newly created basin.These catch basins are percent capture (0.0001%).
Please find the snapshot of related problem.
Thanks.
Hello Hari,
When using the Percent Capture inlet type, those fields are not used because the program only considers the percent capture that you enter, to determine how much flow is captured vs. bypass. See the following related article from our Wiki: Inlet results and input fields not available for some catchbasins
