Can I able to use two different terrain models files at same time? I would like to show existing ground elevations and proposed ground elevations for the same inlets and pipes in my profile plots.
Thank you,
Hari
Hello Hari,
Two terrain models cannot be active at the same time, elements can take elevations from only one terrain model at the moment.
Sushma Choure
Bentley Technical Suppport
As my colleague Sushma pointed out, you cannot apply two terrain models simultaneously to a manhole ground elevation (as there can be only one value for ground elevation). However, if you have multiple terrains such as proposed levels and existing levels then you can create a scenario where you can apply the Existing Terrain levels to your manholes.
Note that you would have to create a separate physical alternative so that your original physical alternative (where the proposed ground elevations are captured as ground elevations) is not disturbed.
Hope this helps.
Yashodhan Joshi
