Ref: https://communities.bentley.com/products/hydraulics___hydrology/f/haestad-hydraulics-and-hydrology-forum/146055/bing-maps-key
Hi, Could you please explain how you created Bing Key and loaded to Model. I am using SewerGems Connect Edition 10.00.00.50 which doesn't show bing map in background layer menu.
Hello Mukesh,
The Bing Maps feature was introduced in CONNECT Edition Update 1, version number 10.01.00.70. See: What's New with SewerGEMS CONNECT Edition Update 1
Upgrading to that version, or the more recent 10.01.01.04 version, will enable you to access this feature. As seen in the following Wiki article, you can obtain a Bing Maps key from Microsoft: How to add background aerial and road map images to your model
Thank you Jesse, for reply.
Mukesh V
Utility Engineer,
Atkins Global, MI & Africa.
Mukesh Vhirodkar
Utilities Designer
WS Atkins, Abu Dhabi, UAE
Here is a relevant video of using the Bing Map's background to align your models. You can set your model as per the map scale which will ensure the model is to the proper scale;
Hope this helps.
Yashodhan Joshi
Thank you Yashodhan Joshi
I will surely try this tool once I upgrade package.
Mukesh v
