Hello all,
I only want to design conduit.Do I need to check mark on start invert and stop invert?
Also, after importing drainage network from inroad I create some of them but the program didn't allowed me to put length, width and grate length for those inlets which I created in stormCAD. Please help me out.
Hari,
Are you referring to automated design? Meaning, do you want StormCAD to only design the conduit sizes, and not the inverts? If so, the property you want to change is "Design start invert" and "Design stop invert". You would set those to False. See:
Is there any way to only adjust the pipe size without changing the invert?
Regarding the second question on uneditable fields for inlets, I had answered that previously in this thread: Input fields for percent capture inlets
