think flow is absolute at same time can't change start node to stop node
Hello Karthikeyan,
You can change / reverse the start and stop nodes in the pipe / conduit properties.
In the pipe properties look for the property of "Node-Reversal". Once you click the ellipsis in the property (three dots) it will reverse / change the start and stop nodes of the pipe.
Here is a reference article which can help you;
How do I reverse the start and stop node for a pipe, conduit, gutter, etc...?
If you have multiple pipes for which you need to reverse the start and stop nodes then refer the following article;
How to globally reverse flow on pipes?
Hope this helps.
Yashodhan Joshi
Answer Verified By: karthikeyan A
thank sir
