Hi, I have a WaterCAD model that is a extension .WCD and there is no .MDB file. I found a Bentley post about converting/saving up to WaterCAD Version 8 but I don't have V7 on my computer to use "as a bridge" to save up. Here is a link to the page explaining the process:
https://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/9295/opening-old-watercad-or-watergems-wcd-model-files-and-preserving-presentation-settings
Bentley, can you save my file to Version 8? I have attached a zipped folder with the file.Water Model.zip
Greg
Thanks for the help Jesse. I was able to change the name of the .mdk to .mdb and open the file. I am checking with the client to see if they have the .mdb so we are sure to be using the most up-to-date model. If they don't I will use the model I converted and check the model against the city utility map for accuracy.
Thanks again,
