Thread Split from: https://communities.bentley.com/products/hydraulics___hydrology/f/haestad-hydraulics-and-hydrology-forum/71046/inputting-24-hr-pressure-and-flow-in-darwin-calibrator
I am using Bentley WaterGEMS CONNECT edition update 1.
I want to calibrate my 24 hour EPS model using observed HGL and flow time series data for 24 hours.
Is above answer valid for me as well?
If not can you please explain how to do calibration?
Harsha
Hello Harsha,
Yes you can import data in Darwin Calibrator via ModelBuilder and the response is valid.
However, it is advisable to not use the entire data for 24 hours as it would prove difficult for the Calibrator to converge on a solution.
You can choose critical time snapshots which are generally maximum pressures or HGL at particular time steps.
For more information refer the following articles;
Using Darwin Calibrator
Water Model Calibration Tips
Hope this helps.
Yashodhan Joshi
Hi Joshi,
Thank you very much. Your response guided me to the correct direction.
