using-unit-loads-and-extreme-flow-factors-after-a-loadbuilder-run
I was going through the page https://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/15903/using-unit-loads-and-extreme-flow-factors-after-a-loadbuilder-run wherin the process to assign unit loads using shapefiles has been explained. For the option 1 provided in this link, the issue is that, some manholes have multiple unit loads applied to them. When we re-initialize the loads, we cannot simply copy paste in such a scenario and need to add multiple unit demands for a single manhole and then apply.
I remember in select series 5, when we used to use load builder and loads were applied as pattern loads, we could simply global edit the load type and make it as unit load therein itself. In connect edition this option is not there.
Most of the cases we have population data in shapefiles which we want to apply to the nearest manhole.
Request you to please look into this.
Best Regards
Jatin Talwar
